Ana içeriğe geç
Axess SPBT1031 Battery Replacement
Neye ihtiyacın var
    1. Axess SPBT1031 Battery Replacement, Red Interface Plate: adım 1, 1 resimden 1.
      • Use a metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
      FixBot'a Sor
      Yorum Ekle
    2. Axess SPBT1031 Battery Replacement: adım 2, 1 resimden 1.
      • Remove the four 5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Axess SPBT1031 Battery Replacement: adım 3, 1 resimden 1.
      Bu adımda kullanılan alet:
      • If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
      FixBot'a Sor
      Yorum Ekle
    4. Axess SPBT1031 Battery Replacement: adım 4, 1 resimden 1.
      • Separate the red interface plate from the black face plate by pulling them apart.
      FixBot'a Sor
      Yorum Ekle
    1. Axess SPBT1031 Battery Replacement, Black Faceplate: adım 5, 1 resimden 1.
      • Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
      • Both screws are 0.55 cm in depth
      FixBot'a Sor
      Yorum Ekle
    2. Axess SPBT1031 Battery Replacement: adım 6, 1 resimden 1.
      • Separate the black face plate from the tube by pulling them apart.
      • Be careful when pulling the wires apart or it will potentially damage the wires due to over stretching.
      FixBot'a Sor
      Yorum Ekle
    1. Axess SPBT1031 Battery Replacement, Battery: adım 7, 1 resimden 1.
      • Look into the back of the black face plate and find the battery which is wrapped in green.
      • Battery is glued in place, remove by peeling it off.
      FixBot'a Sor
      Yorum Ekle
    2. Axess SPBT1031 Battery Replacement: adım 8, 1 resimden 1.
      • Once the glue is removed, look into the red interface plate and then locate the bottom of the motherboard.
      • On the bottom of the motherboard, locate the black and red wire connected to the plastic red socket and remove the white insert from this socket.
      FixBot'a Sor
      Yorum Ekle
    3. Axess SPBT1031 Battery Replacement: adım 9, 1 resimden 1.
      • Run the black and red wire in reverse through the hole in the black face plate to remove the battery.
      • Remove the battery from the black face plate.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Elvira Lou Evangelista
975 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-6, Botvin Spring 2016 UMass Dartmouth, Team 8-6, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G6
3 Üyeler
16 adet Kılavuz yazıldı
3Kılavuz Yorumları
ok, so is there any reason that I would not be able to put in a bigger battery for longer play? I realize I would have to mount it differently.
bartman777 - Yanıt Paylaş
why it is easily connect this blue tooth to cellphone done connecting to computer. Well not connect any of my 3 laptop computer ??????????????
htosee3791 - Yanıt Paylaş
What battery is used for the speaker?
De'Eric Dortch - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 54
Her zaman: 9,400
