Ana içeriğe geç
Axess SPBT1031 Subwoofer Replacement
Neye ihtiyacın var
    1. Axess SPBT1031 Subwoofer Replacement, Subwoofer: adım 1, 1 resimden 1.
      • Look at the side of the speaker without the red interface plate; there will be a red ring around the mesh but no buttons on the side.
      • Remove the two 5.5 mm screws from the top and bottom of the black face plate using a Phillips #1 screwdriver.
      • Do not remove the plate yet.
      FixBot'a Sor
      Yorum Ekle
    2. Axess SPBT1031 Subwoofer Replacement: adım 2, 1 resimden 1.
      • Use a metal spudger to remove the mesh speaker cover by wedging the narrow end into the center of the outer edge of the mesh touching the red plate.
      FixBot'a Sor
      Yorum Ekle
    3. Axess SPBT1031 Subwoofer Replacement: adım 3, 2 resimden 1. Axess SPBT1031 Subwoofer Replacement: adım 3, 2 resimden 2.
      • Remove four 5.5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
      • For subwoofer replacement there will be four screws to remove and four bolts as well. The bolts are used for alignment and cannot be removed.
      FixBot'a Sor
      Yorum Ekle
    4. Axess SPBT1031 Subwoofer Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • If the screws are difficult to remove, use the tweezers to twist and pick them out.
      FixBot'a Sor
      Yorum Ekle
    5. Axess SPBT1031 Subwoofer Replacement: adım 5, 1 resimden 1.
      • Separate the red plate from the black face plate by removing the black plate from the tube and pushing on the inside of the subwoofer.
      • Be careful not to damage the black face plate or red plate as you pull them apart.
      • You may place the black faceplate back on the tube, but do not screw it back in yet.
      FixBot'a Sor
      Yorum Ekle
    6. Axess SPBT1031 Subwoofer Replacement: adım 6, 2 resimden 1. Axess SPBT1031 Subwoofer Replacement: adım 6, 2 resimden 2.
      • To remove the the wires from the subwoofer terminals, use a soldering iron to reheat the solder at each of the four points of connection.
      FixBot'a Sor
      Yorum Ekle
    7. Axess SPBT1031 Subwoofer Replacement: adım 7, 1 resimden 1.
      Desoldering Pump
      $3.99
      FixBot'a Sor
      Yorum Ekle
    8. Axess SPBT1031 Subwoofer Replacement: adım 8, 1 resimden 1.
      • Remove the old subwoofer.
      • Connect the brown wires to the positive terminals and the black ones to the negative terminals when re-soldering.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Elvira Lou Evangelista
975 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-6, Botvin Spring 2016 UMass Dartmouth, Team 8-6, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G6
3 Üyeler
16 adet Kılavuz yazıldı
1Rehber Yorum
I Ned to replace the charger conection and I need the parts please u can email me at elpaleterolopez@Gmail.com or call me at 6613402547
Ramon lopez - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 2,041
