Ana içeriğe geç
Axess TA2513-10WT Back Cover Replacement
Neye ihtiyacın var
  1. Axess TA2513-10WT Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Back Cover Replacement: adım 2, 3 resimden 1. Axess TA2513-10WT Back Cover Replacement: adım 2, 3 resimden 2. Axess TA2513-10WT Back Cover Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Back Cover Replacement: adım 3, 1 resimden 1.
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Back Cover Replacement: adım 4, 1 resimden 1.
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hayley Rabe
125 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 üyesi
BU-SHAVER-S15S6G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 232
