Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Use this guide to replace the side buttons on the Axess TA2513-10WT.
Parçalar
Hiçbir parça belirtilmedi.
  1. Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons. Slide the plastic opening tool gently along the sides. If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  5. Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  6. Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner. Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  7. Unlatch the clear rubber holder from the posts with the tweezers. Unlatch the clear rubber holder from the posts with the tweezers.
    • Unlatch the clear rubber holder from the posts with the tweezers.
  8. With tweezers, pull the rubber holder from the back cover completely. With tweezers, pull the rubber holder from the back cover completely.
    • With tweezers, pull the rubber holder from the back cover completely.
  9. Remove the individual buttons with tweezers. Remove the individual buttons with tweezers. Remove the individual buttons with tweezers.
    • Remove the individual buttons with tweezers.
Sonuç
Lori Scott
101 İtibar
1 Kılavuz yazıldı
Takım
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 üyesi
BU-SHAVER-S15S6G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 134
