Ana içeriğe geç
Axess TA2513-10WT Side Button Replacement
Neye ihtiyacın var
  1. Axess TA2513-10WT Side Button Replacement, Back Cover: adım 1, 1 resimden 1.
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Side Button Replacement: adım 2, 3 resimden 1. Axess TA2513-10WT Side Button Replacement: adım 2, 3 resimden 2. Axess TA2513-10WT Side Button Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Side Button Replacement: adım 3, 1 resimden 1.
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Side Button Replacement: adım 4, 1 resimden 1.
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Side Button Replacement, Buttons: adım 5, 2 resimden 1. Axess TA2513-10WT Side Button Replacement, Buttons: adım 5, 2 resimden 2.
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  6. Axess TA2513-10WT Side Button Replacement: adım 6, 2 resimden 1. Axess TA2513-10WT Side Button Replacement: adım 6, 2 resimden 2.
    • Unlatch the clear rubber holder from the posts with the tweezers.
  7. Axess TA2513-10WT Side Button Replacement: adım 7, 2 resimden 1. Axess TA2513-10WT Side Button Replacement: adım 7, 2 resimden 2.
    • With tweezers, pull the rubber holder from the back cover completely.
  8. Axess TA2513-10WT Side Button Replacement: adım 8, 3 resimden 1. Axess TA2513-10WT Side Button Replacement: adım 8, 3 resimden 2. Axess TA2513-10WT Side Button Replacement: adım 8, 3 resimden 3.
    • Remove the individual buttons with tweezers.
Sonuç
Lori Scott
101 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 üyesi
BU-SHAVER-S15S6G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 229
