Ana içeriğe geç
Axess TA2513-10WT Speaker Replacement
Neye ihtiyacın var
  1. Axess TA2513-10WT Speaker Replacement, Back Cover: adım 1, 1 resimden 1.
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Speaker Replacement: adım 2, 3 resimden 1. Axess TA2513-10WT Speaker Replacement: adım 2, 3 resimden 2. Axess TA2513-10WT Speaker Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Speaker Replacement: adım 3, 1 resimden 1.
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • Remove tape attached to black and red speaker wires.
  6. Axess TA2513-10WT Speaker Replacement: adım 6, 1 resimden 1.
    • Identify the four speaker nodes.
    • From left to right the nodes are "SPKP1", "SPKN1", "LN", and "LP"
  7. Axess TA2513-10WT Speaker Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Place the soldering tool on the speaker node labeled "SPKP1" and quickly remove the red wire with tweezers.
  8. Axess TA2513-10WT Speaker Replacement: adım 8, 1 resimden 1.
    • Place the soldering tool on the speaker node labeled "SPKN1" and quickly remove the black wire with tweezers.
  9. Axess TA2513-10WT Speaker Replacement: adım 9, 1 resimden 1.
    • Place the soldering tool on the speaker node labeled "LP" and quickly remove the black wire with the tweezers.
  10. Axess TA2513-10WT Speaker Replacement: adım 10, 1 resimden 1.
    • Place the soldering tool on the speaker node labeled "LN" and quickly remove the red wire with tweezers.
Sonuç
Steven Kavanagh
301 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 üyesi
BU-SHAVER-S15S6G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 320
