Ana içeriğe geç
Azpen A701 General Disassembly Prerequisite Guide Replacement
Neye ihtiyacın var
  1. Azpen A701 General Disassembly Prerequisite Guide Replacement, General Disassembly Prerequisite Guide: adım 1, 1 resimden 1.
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 General Disassembly Prerequisite Guide Replacement: adım 2, 2 resimden 1. Azpen A701 General Disassembly Prerequisite Guide Replacement: adım 2, 2 resimden 2.
    • Pry open the back piece with the plastic spudger.
    • Remove the back piece from the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 General Disassembly Prerequisite Guide Replacement: adım 3, 1 resimden 1.
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 General Disassembly Prerequisite Guide Replacement: adım 4, 1 resimden 1.
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael
568 İtibar
4 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G1
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 481
