Ana içeriğe geç
Azpen A701 Screen Replacement
Neye ihtiyacın var
  1. Azpen A701 Screen Replacement, General Disassembly Prerequisite Guide: adım 1, 1 resimden 1.
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
    FixBot'a Sor
    Yorum Ekle
  2. Azpen A701 Screen Replacement: adım 2, 2 resimden 1. Azpen A701 Screen Replacement: adım 2, 2 resimden 2.
    • Pry open the back piece with the plastic spudger.
    • Remove the back piece from the device.
    • The back panel may be difficult to pry off, use gentle force.
    FixBot'a Sor
    Yorum Ekle
  3. Azpen A701 Screen Replacement: adım 3, 1 resimden 1.
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
    FixBot'a Sor
    Yorum Ekle
  4. Azpen A701 Screen Replacement: adım 4, 1 resimden 1.
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
    FixBot'a Sor
    Yorum Ekle
  5. Azpen A701 Screen Replacement, Screen: adım 5, 3 resimden 1. Azpen A701 Screen Replacement, Screen: adım 5, 3 resimden 2. Azpen A701 Screen Replacement, Screen: adım 5, 3 resimden 3.
    • Disconnect the two largest (of the three) ZIF cables by prying open the flap with a plastic spudger to gently remove them.
    FixBot'a Sor
    Yorum Ekle
  6. Azpen A701 Screen Replacement: adım 6, 1 resimden 1.
    • Peel off the black tape from the corner of the motherboard (indicated by the blue surface of the device).
    FixBot'a Sor
    Yorum Ekle
  7. Azpen A701 Screen Replacement: adım 7, 3 resimden 1. Azpen A701 Screen Replacement: adım 7, 3 resimden 2. Azpen A701 Screen Replacement: adım 7, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the three screws that connect the motherboard to the front panel.
    • When removing the motherboard, be cautious of the gray wire connected from the motherboard to the actual device.
    FixBot'a Sor
    Yorum Ekle
  8. Azpen A701 Screen Replacement: adım 8, 1 resimden 1.
    • Remove the motherboard and the battery and set aside.
    FixBot'a Sor
    Yorum Ekle
  9. Azpen A701 Screen Replacement: adım 9, 3 resimden 1. Azpen A701 Screen Replacement: adım 9, 3 resimden 2. Azpen A701 Screen Replacement: adım 9, 3 resimden 3.
    • Remove the small orange tape attached with a gray wire from the top corner of the device. This is the antenna.
    • Use a plastic spudger around the silver lining within the device to pry the screen off.
    • The metal screen assembly is two pieces. When removing the screen, make sure to pry off both pieces at once.
    FixBot'a Sor
    Yorum Ekle
  10. Azpen A701 Screen Replacement: adım 10, 1 resimden 1.
    • Replace the broken screen and reverse the steps to re-assemble the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael
568 İtibar
4 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G1
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 876
