Ana içeriğe geç
Azpen A909 Back Cover Replacement
Neye ihtiyacın var
  1. Azpen A909 Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
  2. Azpen A909 Back Cover Replacement: adım 2, 1 resimden 1.
    • Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
  3. Azpen A909 Back Cover Replacement: adım 3, 1 resimden 1.
    • After prying open all of the anchoring points, the cover will lift off of the tablet.
    • To replace the cover, simply snap it back in place and re-insert the two screws. Because the speaker is not fully fixed to the interior of the tablet, make sure that it is in the position that will allow it to fit inside the speaker mounting on the cover.
Sonuç
Karoly Fodor
475 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Duarte Spring 2015 UMass Dartmouth, Team 3-5, Duarte Spring 2015 üyesi
UMASSD-DUARTE-S15S3G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 446
