Ana içeriğe geç
B-Flat Clarinet Key Pad Replacement
Neye ihtiyacın var
  1. B-Flat Clarinet Key Pad Replacement, Key Pad: adım 1, 1 resimden 1.
    • Disassemble the clarinet until you are handling only the joint containing the missing or damaged pad.
    • If the pad is missing completely, skip to step 3.
  2. B-Flat Clarinet Key Pad Replacement: adım 2, 1 resimden 1.
    • Remove the damaged pad by inserting the screwdriver under the pad and peeling it off the key.
  3. B-Flat Clarinet Key Pad Replacement: adım 3, 1 resimden 1.
    • Squeeze a dot of super glue into the empty key.
    • Take care to not overfill the key or glue will ooze out and potentially bind the key to the instrument.
  4. B-Flat Clarinet Key Pad Replacement: adım 4, 1 resimden 1.
    • Quickly insert the new pad into the key, taking care not to smear the glue.
  5. B-Flat Clarinet Key Pad Replacement: adım 5, 1 resimden 1.
    • Using the screwdriver, press the pad down to secure it to the key
    • Hold the pad for 5 seconds to let the glue harden
  6. B-Flat Clarinet Key Pad Replacement: adım 6, 1 resimden 1.
    • Place a small piece of paper between the key and the instrument to avoid residual glue binding the key to the instrument
    • Let the instrument sit out for a few minutes to let the glue fully dry
Bitiş Çizgisi
Rachel Strobel
101 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
From my point of view it would be better to disassemble the key and clean it before gluing a new pad. The best glue in these cases is shellac
Roberto Ottaviani - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 1,687
