Giriş
While a clarinet is used in this guide, this technique could be used on other woodwind instruments. A pad on a clarinet needs to be replaced if it falls off or becomes damaged. In this case, the protective film on the pad has fallen off.
Neye ihtiyacın var
Disassemble the clarinet until you are handling only the joint containing the missing or damaged pad.
If the pad is missing completely, skip to step 3.
Neredeyse bitti!
Bitiş Çizgisi
1Rehber Yorum
From my point of view it would be better to disassemble the key and clean it before gluing a new pad. The best glue in these cases is shellac
