Giriş
The heating plate under the basket could get dents or be damaged with usage. This could cause the basket to not fit as well and make it pop out. When that happens, the user should replace the heating plate with a new one. Thus this guide shows how to replace the plate.
Neye ihtiyacın var
Turn the device off and make sure it is cooled down. Then place the device in front of you and take the drawer out by placing a hand on the handle and pull towards you. Make sure the plug is out of the way before starting any of the following steps.
Slide the clear lock away from the button and press down on the release button to release the basket from the drawer.
Bir başkası bu kılavuzu tamamladı.
