Ana içeriğe geç
BEM Mojo 2 Charging Base Battery Replacement
Neye ihtiyacın var
  1. BEM Mojo 2 Charging Base Battery Replacement, Charging Base Battery: adım 1, 1 resimden 1.
    • Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
    FixBot'a Sor
    Yorum Ekle
  2. BEM Mojo 2 Charging Base Battery Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
    FixBot'a Sor
    Yorum Ekle
  3. BEM Mojo 2 Charging Base Battery Replacement: adım 3, 2 resimden 1. BEM Mojo 2 Charging Base Battery Replacement: adım 3, 2 resimden 2.
    • Pull the top cover off of the charging base to reveal the internal chip.
    • Use the plastic opening tool to pry the battery from the top cover.
    • Caution: Be careful when detaching battery from top cover as to not damage any of the wires attached to it.
    FixBot'a Sor
    Yorum Ekle
  4. BEM Mojo 2 Charging Base Battery Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to carefully detach the wires from the internal chip.
    • Caution: Be careful to not damage the internal chip when removing the wires.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Rachel Iacoboni
618 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G1, Johnson Spring 2018 Baylor, Team S1-G1, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 42
Her zaman: 825
