Ana içeriğe geç
Giriş
The charging base motherboard may need to be replaced due to the ON/OFF switch not working properly. It is important to make sure before replacing the charging base motherboard that it is the proper cause of the issue. Before replacing, try wiping down and cleaning the buttons on the device with a clean, damp towel. Also make sure that when pushing the button to the ON position that you hear a click indicating that the device should turn ON. If both of these attempts have been made with no results, please use this guide to replace the charging base motherboard.
  1. Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
    • Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
  2. Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
    • Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Pull the top cover off of the charging base to reveal the internal chip. Use the plastic opening tool to pry the battery from the top cover.
    • Pull the top cover off of the charging base to reveal the internal chip.
    • Use the plastic opening tool to pry the battery from the top cover.
    • Caution: Be careful when detaching battery from top cover as to not damage any of the wires attached to it.
  5. Use the tweezers to carefully detach the wires from the internal chip.
    • Use the tweezers to carefully detach the wires from the internal chip.
    • Caution: Be careful to not damage the internal chip when removing the wires.
  6. Use the tweezers to remove the red wire attached to the motherboard.
    • Use the tweezers to remove the red wire attached to the motherboard.
  7. Use the plastic opening tool to carefully lift and remove the motherboard from the charging base.
    • Use the plastic opening tool to carefully lift and remove the motherboard from the charging base.
Sonuç
Rachel Iacoboni
567 İtibar
5 adet Kılavuz yazıldı
Takım
Baylor, Team S1-G1, Johnson Spring 2018 Baylor, Team S1-G1, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 47
