Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
Pull the top cover off of the charging base to reveal the internal chip.
Use the plastic opening tool to pry the battery from the top cover.
Use the tweezers to carefully detach the wires from the internal chip.
Use the tweezers to remove the red wire attached to the motherboard.
Use the plastic opening tool to carefully lift and remove the motherboard from the charging base.
Bir başkası bu kılavuzu tamamladı.
