Ana içeriğe geç
BEM Mojo 2 Speaker Battery Replacement
Neye ihtiyacın var
  1. BEM Mojo 2 Speaker Battery Replacement, Speaker Battery: adım 1, 1 resimden 1.
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Battery Replacement: adım 2, 1 resimden 1.
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Battery Replacement: adım 3, 1 resimden 1.
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Battery Replacement: adım 4, 1 resimden 1.
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Battery Replacement: adım 5, 1 resimden 1.
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
Sonuç
Rachel Iacoboni
618 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G1, Johnson Spring 2018 Baylor, Team S1-G1, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 520
