Ana içeriğe geç
BLACK and DECKER BDERO100 Hook and Loop System Replacement
Neye ihtiyacın var
  1. BLACK and DECKER BDERO100 Hook and Loop System Replacement, Hook and Loop System: adım 1, 1 resimden 1.
    • Remove the sanding paper from the velcro.
  2. BLACK and DECKER BDERO100 Hook and Loop System Replacement: adım 2, 1 resimden 1.
    • Select the JIS - J1 bit or the most appropriate bit to match the screws for your model.
  3. BLACK and DECKER BDERO100 Hook and Loop System Replacement: adım 3, 2 resimden 1. BLACK and DECKER BDERO100 Hook and Loop System Replacement: adım 3, 2 resimden 2.
    • Use the Bit Driver to take off the four 12.5 mm Phillips screws at the base of the hook-and-loop system.
    • Be careful not to lose the lock washers (black rings).
  4. BLACK and DECKER BDERO100 Hook and Loop System Replacement: adım 4, 2 resimden 1. BLACK and DECKER BDERO100 Hook and Loop System Replacement: adım 4, 2 resimden 2.
    • Once all screws and washers have been removed, hold the hook and loop system and separate it from the device.
Sonuç
Christian Moss
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Sullivan Spring 2016 USF Tampa, Team 1-5, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G5
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 1,646
