Ana içeriğe geç
BLU Advance 4.0 Charger Port Replacement
Neye ihtiyacın var
  1. Dikkatli ol: adımlar 1-3 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    BLU Advance 4.0 Charger Port Replacement, Removing the back cover: adım 1, 2 resimden 1. BLU Advance 4.0 Charger Port Replacement, Removing the back cover: adım 1, 2 resimden 2.
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
    I dont have anything like that on my phone
    randy vanwyck - Yanıt
  2. BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: adım 2, 3 resimden 1. BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: adım 2, 3 resimden 2. BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: adım 2, 3 resimden 3.
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Charger Port Replacement, Separating motherboard from screen: adım 3, 1 resimden 1.
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
  4. BLU Advance 4.0 Charger Port Replacement, Charger Port: adım 4, 2 resimden 1. BLU Advance 4.0 Charger Port Replacement, Charger Port: adım 4, 2 resimden 2.
    • Once phone is completely disassmbled, you will take your soldering iron to the charger port to remove it.
    • Be careful to make sure you take a soldering wick to absorb the solder.
    • Touching other pieces on the motherboard may alter phones capabilities!
  5. BLU Advance 4.0 Charger Port Replacement: adım 5, 1 resimden 1.
    • Once the old charger port is removed, take the new one and place it in the same spot. You will need to solder this piece to ensure that it stays connected.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jon Sclar
292 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G2
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Where can I get a charging port for my BLU studio XL2
Debbie - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,432
