Ana içeriğe geç
BLU Advance 4.0 Screen Replacement
Neye ihtiyacın var
  1. BLU Advance 4.0 Screen Replacement, Removing the back cover: adım 1, 2 resimden 1. BLU Advance 4.0 Screen Replacement, Removing the back cover: adım 1, 2 resimden 2.
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
    FixBot'a Sor
    Yorum Ekle
  2. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: adım 2, 3 resimden 1. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: adım 2, 3 resimden 2. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: adım 2, 3 resimden 3.
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  3. BLU Advance 4.0 Screen Replacement, Separating motherboard from screen: adım 3, 1 resimden 1.
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
    FixBot'a Sor
    Yorum Ekle
  4. BLU Advance 4.0 Screen Replacement, Screen: adım 4, 2 resimden 1. BLU Advance 4.0 Screen Replacement, Screen: adım 4, 2 resimden 2.
    • The screen connector is located near the back camera and charger port.
    • Remove the attached screen by gently tugging the cord that connects it to main frame.
    • Pull gently to avoid damaging the connected cable.
    FixBot'a Sor
    Yorum Ekle
  5. BLU Advance 4.0 Screen Replacement: adım 5, 2 resimden 1. BLU Advance 4.0 Screen Replacement: adım 5, 2 resimden 2.
    • After screen removal, you should be left with the old screen and a plug-in tab .
    • Leave the motherboard and inner screen in one piece.
    • If the inner screen is cracked, replacing the outer screen is useless.
    FixBot'a Sor
    Yorum Ekle
  6. BLU Advance 4.0 Screen Replacement, Placing in new screen: adım 6, 1 resimden 1.
    • Work backwards by carefully sliding in the new screen's plug-in tab into the screen connector.
    • The phone will not have sensitivity if the plug-in tab is damaged.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jon Sclar
292 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G2
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 56
Her zaman: 4,361
