Ana içeriğe geç
BLU Dash 3.5 Camera Replacement
Neye ihtiyacın var
  1. BLU Dash 3.5 Camera Replacement, Battery: adım 1, 3 resimden 1. BLU Dash 3.5 Camera Replacement, Battery: adım 1, 3 resimden 2. BLU Dash 3.5 Camera Replacement, Battery: adım 1, 3 resimden 3.
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Camera Replacement: adım 2, 2 resimden 1. BLU Dash 3.5 Camera Replacement: adım 2, 2 resimden 2.
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Camera Replacement, Camera: adım 3, 3 resimden 1. BLU Dash 3.5 Camera Replacement, Camera: adım 3, 3 resimden 2. BLU Dash 3.5 Camera Replacement, Camera: adım 3, 3 resimden 3.
    • Use the J000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Camera Replacement: adım 4, 2 resimden 1. BLU Dash 3.5 Camera Replacement: adım 4, 2 resimden 2.
    • Locate camera module on inside of the black plastic back panel
    • Note the orientation of the camera.
    • Use tweezers to carefully remove the camera.
Sonuç
victoria dorony
22 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-2, Garvin Fall 2015 Ohio State, Team 1-2, Garvin Fall 2015 üyesi
OSU-GARVIN-F15S1G2
4 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 325
