Giriş
This guide will go through the process of replacing the ear speaker on the front of this device.
Neye ihtiyacın var
Start by locating the slot on the lower right corner of the device.
Insert the opening tool into the slot.
Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
Use the 000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
Use the opening tool to pry open the plastic back panel to expose the motherboard.
Use tweezers to lift the screen wire tab where the cable is connected.
Use the opening tool to pry the motherboard from the front face plate.
