Ana içeriğe geç
BLU Dash 3.5 Screen Assembly Replacement
Neye ihtiyacın var
  1. BLU Dash 3.5 Screen Assembly Replacement, Battery: adım 1, 3 resimden 1. BLU Dash 3.5 Screen Assembly Replacement, Battery: adım 1, 3 resimden 2. BLU Dash 3.5 Screen Assembly Replacement, Battery: adım 1, 3 resimden 3.
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Screen Assembly Replacement: adım 2, 2 resimden 1. BLU Dash 3.5 Screen Assembly Replacement: adım 2, 2 resimden 2.
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Screen Assembly Replacement, Volume and Lock Button: adım 3, 2 resimden 1. BLU Dash 3.5 Screen Assembly Replacement, Volume and Lock Button: adım 3, 2 resimden 2.
    • Use the 000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Screen Assembly Replacement: adım 4, 2 resimden 1. BLU Dash 3.5 Screen Assembly Replacement: adım 4, 2 resimden 2.
    • Remove volume and lock buttons by lifting them gently from the casing.
  5. BLU Dash 3.5 Screen Assembly Replacement, Screen Assembly: adım 5, 2 resimden 1. BLU Dash 3.5 Screen Assembly Replacement, Screen Assembly: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to lift the tab where the cable is connected.
    • Use the opening tool to pry the motherboard from the front face plate.
  6. BLU Dash 3.5 Screen Assembly Replacement: adım 6, 2 resimden 1. BLU Dash 3.5 Screen Assembly Replacement: adım 6, 2 resimden 2.
    • Use opening tool to pry off the screen.
    • Use a soldering tool to melt the contact between the motherboard and the screen
    • Solder new screen contacts to the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeffrey Dlugosz
104 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-2, Garvin Fall 2015 Ohio State, Team 1-2, Garvin Fall 2015 üyesi
OSU-GARVIN-F15S1G2
4 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 709
