Ana içeriğe geç
BLU Dash 3.5 Volume and Lock Button Replacement
Neye ihtiyacın var
  1. BLU Dash 3.5 Volume and Lock Button Replacement, Battery: adım 1, 3 resimden 1. BLU Dash 3.5 Volume and Lock Button Replacement, Battery: adım 1, 3 resimden 2. BLU Dash 3.5 Volume and Lock Button Replacement, Battery: adım 1, 3 resimden 3.
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Volume and Lock Button Replacement: adım 2, 2 resimden 1. BLU Dash 3.5 Volume and Lock Button Replacement: adım 2, 2 resimden 2.
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Volume and Lock Button Replacement, Volume and Lock Button: adım 3, 2 resimden 1. BLU Dash 3.5 Volume and Lock Button Replacement, Volume and Lock Button: adım 3, 2 resimden 2.
    • Use the 000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Volume and Lock Button Replacement: adım 4, 2 resimden 1. BLU Dash 3.5 Volume and Lock Button Replacement: adım 4, 2 resimden 2.
    • Remove volume and lock buttons by lifting them gently from the casing.
Sonuç
Paige Shirley
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Harley Spring 2017 IUPUI, Team S1-G2, Harley Spring 2017 üyesi
IUPUI-HARLEY-S17S1G2
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 199
