Ana içeriğe geç
BLU Dash JR D140 Digitizer Replacement
Neye ihtiyacın var
  1. BLU Dash JR D140 Digitizer Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
  2. BLU Dash JR D140 Digitizer Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool or finger, pull out the battery.
  3. BLU Dash JR D140 Digitizer Replacement, Digitizer: adım 3, 1 resimden 1.
    • Remove the four 4.0mm Phillips #1 screws.
  4. BLU Dash JR D140 Digitizer Replacement: adım 4, 1 resimden 1.
    • Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • The volume button will pop out.
  5. BLU Dash JR D140 Digitizer Replacement: adım 5, 1 resimden 1.
    • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
  6. BLU Dash JR D140 Digitizer Replacement: adım 6, 1 resimden 1.
    • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
  7. BLU Dash JR D140 Digitizer Replacement: adım 7, 1 resimden 1.
    • Pull the ribbon cable out of the ZIF connector.
  8. BLU Dash JR D140 Digitizer Replacement: adım 8, 1 resimden 1.
    • When the ribbon cable is removed from the ZIF connector, peel off the power, sticky button using a plastic opening tool.
  9. BLU Dash JR D140 Digitizer Replacement: adım 9, 1 resimden 1.
    • Peel off the volume sticky button.
  10. BLU Dash JR D140 Digitizer Replacement: adım 10, 2 resimden 1. BLU Dash JR D140 Digitizer Replacement: adım 10, 2 resimden 2.
    • Separate the screen cover from the motherboard using the plastic opening tool. And don't forget that your phone can mess up if u separate the motherboard from the screen cover
    • Make sure that the LCD screen stays attached to the motherboard while doing this.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Nathanael
233 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,312
