Ana içeriğe geç
BLU Dash Music 4.0 Headphone Jack Replacement
Neye ihtiyacın var
  1. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Back Cover: adım 1, 1 resimden 1.
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Battery: adım 2, 1 resimden 1.
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: adım 3, 2 resimden 1. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: adım 3, 2 resimden 2.
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: adım 4, 2 resimden 1. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: adım 4, 2 resimden 2.
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the two covers apart.
  5. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: adım 5, 2 resimden 1. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: adım 5, 2 resimden 2.
    • Insert the plastic opening tool between the black pad and the circuit board. Then gently pry off the black pad.
    • This will make the connections of the charging port more accessible.
  6. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: adım 6, 2 resimden 1. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: adım 6, 2 resimden 2.
    • Using a soldering iron and a pair of pliers, melt the soldering connections around the headphone jack.
    • Quickly pull off the current headphone jack while the soldering connections are still soft.
  7. BLU Dash Music 4.0 Headphone Jack Replacement, Mount the New Headphone Jack: adım 7, 1 resimden 1.
    • Mount the new headphone jack such that the prongs of the headphone jack line up with the soldering connections.
    • Using a soldering iron, solder the connections in place.
Sonuç
Lioma Terrero Soto
525 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G8
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 401
