Ana içeriğe geç
BLU Dash Music 4.0 Speaker Replacement
Neye ihtiyacın var
  1. BLU Dash Music 4.0 Speaker Replacement, Remove the Back Cover: adım 1, 1 resimden 1.
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Speaker Replacement, Remove the Battery: adım 2, 1 resimden 1.
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: adım 3, 2 resimden 1. BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: adım 3, 2 resimden 2.
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: adım 4, 2 resimden 1. BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: adım 4, 2 resimden 2.
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the covers apart.
  5. BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: adım 5, 3 resimden 1. BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: adım 5, 3 resimden 2. BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: adım 5, 3 resimden 3.
    • Locate the speaker
    • Wedge the plastic opening tool between the speaker and the circuit board. Gently pry the speaker off the circuit board.
    • Use a soldering iron to remove the two wires that connect the speaker to the circuit board.
  6. BLU Dash Music 4.0 Speaker Replacement, Place the New Speaker: adım 6, 1 resimden 1.
    • Use the soldering iron to connect the two wires, that are attached to the speaker, to the circuit board.
    • Place the new speaker onto the circuit board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lioma Terrero Soto
525 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G8
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 471
