Ana içeriğe geç
BLU Energy X Battery Replacement
Neye ihtiyacın var
  1. BLU Energy X Battery Replacement, Battery: adım 1, 3 resimden 1. BLU Energy X Battery Replacement, Battery: adım 1, 3 resimden 2. BLU Energy X Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the back case using plastic opening tool.
  2. BLU Energy X Battery Replacement: adım 2, 2 resimden 1. BLU Energy X Battery Replacement: adım 2, 2 resimden 2.
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X Battery Replacement: adım 3, 3 resimden 1. BLU Energy X Battery Replacement: adım 3, 3 resimden 2. BLU Energy X Battery Replacement: adım 3, 3 resimden 3.
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sishun Wang
630 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-2, Eyestone Spring 2016 USF Tampa, Team 12-2, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S12G2
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
Hi. I my short Band Aid q makes connection between the battery and cell .. q do ? They are fixable ?
tamara diale - Yanıt
directions were pretty straightforward... mine had a tiny sticker w/ the "B" in BLU printed, covering the screw on the upper left corner that needed removal (warranty?). otherwise, simple replacement...thanks!
joe doe (ch555x) - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 1,977
