Ana içeriğe geç
BLU Energy X Motherboard Replacement
Neye ihtiyacın var
  1. BLU Energy X Motherboard Replacement, Battery: adım 1, 3 resimden 1. BLU Energy X Motherboard Replacement, Battery: adım 1, 3 resimden 2. BLU Energy X Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the back case using plastic opening tool.
  2. BLU Energy X Motherboard Replacement: adım 2, 2 resimden 1. BLU Energy X Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X Motherboard Replacement: adım 3, 3 resimden 1. BLU Energy X Motherboard Replacement: adım 3, 3 resimden 2. BLU Energy X Motherboard Replacement: adım 3, 3 resimden 3.
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
  4. BLU Energy X Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. BLU Energy X Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Use the flat end of a spudger to flip up the black retaining flap on the ZIF connector.
  5. BLU Energy X Motherboard Replacement: adım 5, 2 resimden 1. BLU Energy X Motherboard Replacement: adım 5, 2 resimden 2.
    • Gently pull the ribbon cable free of the ZIF connector.
  6. BLU Energy X Motherboard Replacement: adım 6, 2 resimden 1. BLU Energy X Motherboard Replacement: adım 6, 2 resimden 2.
    • Gently peel up the antenna.
    • This is secured with some light adhesive, so some force may be required.
  7. BLU Energy X Motherboard Replacement: adım 7, 3 resimden 1. BLU Energy X Motherboard Replacement: adım 7, 3 resimden 2. BLU Energy X Motherboard Replacement: adım 7, 3 resimden 3.
    • Gently rotate the motherboard up so that the front-facing camera is pointed towards you.
    • Use the pointed end of a spudger to disconnect the antenna cable and the ribbon cable.
  8. BLU Energy X Motherboard Replacement: adım 8, 2 resimden 1. BLU Energy X Motherboard Replacement: adım 8, 2 resimden 2.
    • Lift the motherboard up and out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geoff Wacker
90.010 İtibar
89 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 420
