Ana içeriğe geç
BLU Energy X Plus Camera Replacement
Görüntüleme: 901
İstatistikleri görüntüle:
Son 24 Saat:
2
Son 7 Gün:
13
Son 30 Gün:
79
Her zaman:
901
Yorumlar: 0
Hiç kimse bu kılavuza yorum bırakmadı. Birinci olacak mısın?
Go to guide comments
Tamamlandı: 0
Hiç kimse bu kılavuzu "tamamlandı" olarak işaretlemedi. İlk mi olacaksın?
Sık Kullanılanlar: 0
Hiç kimse bu kılavuzu favorilere eklemedi (ve abone olmadı). İlk mi olacaksın?
Gerekli Süre: Tahmin yok
Zorluk: Orta
You may need to replace the Camera on your BLU Energy X Plus due to various reasons. This guide will teach you how to replace the BLU Energy X Plus camera with all the necessary instructions and pictures to help you throughout the replacement process. This is a three step process that comes after the Battery Replacement guide. If done correctly, you will have replaced the camera on the device.
Neye ihtiyacın var
Aletler
    1. BLU Energy X Plus Camera Replacement, Battery: adım 1, 2 resimden 1. BLU Energy X Plus Camera Replacement, Battery: adım 1, 2 resimden 2.
      • Before disassembling your BLU Energy X Plus, make sure it is powered off.
      • Flip your device to the left side facing up and take out the SD card tray using the SIM card eject tool. You will insert the tool in at an angle and lift the tray up.
      FixBot'a Sor
      Yorum Ekle
    2. BLU Energy X Plus Camera Replacement: adım 2, 2 resimden 1. BLU Energy X Plus Camera Replacement: adım 2, 2 resimden 2.
      • Flip your device to the right side facing up and use the SIM card eject tool to remove the SIM card by pushing the tool in the hole. You will feel a button click and the tray should slide out 2mm. You will then use your fingers to pull the tray out.
      FixBot'a Sor
      Yorum Ekle
    3. BLU Energy X Plus Camera Replacement: adım 3, 1 resimden 1.
      • Flip your device over so your back cover is facing up.
      FixBot'a Sor
      Yorum Ekle
    4. BLU Energy X Plus Camera Replacement: adım 4, 2 resimden 1. BLU Energy X Plus Camera Replacement: adım 4, 2 resimden 2.
      • Take the blue plastic opening tool and insert it in-between the back of the phone and the chrome trim. Go all the way around the device slowly to take the back cover off.
      FixBot'a Sor
      Yorum Ekle
    5. BLU Energy X Plus Camera Replacement: adım 5, 2 resimden 1. BLU Energy X Plus Camera Replacement: adım 5, 2 resimden 2.
      • Remove the six silver screws from the cover plate, and one black screw from the top.
      • Use the screwdriver head J000 to remove all the screws.
      • Six silver screws, all 1.5mm in length.
      • One black screw, 1mm in length.
      FixBot'a Sor
      Yorum Ekle
    6. BLU Energy X Plus Camera Replacement: adım 6, 1 resimden 1.
      • After all the screws are out, lift the protective metal cover off of the phone. Lift from the bottom of the cover.
      FixBot'a Sor
      Yorum Ekle
    7. BLU Energy X Plus Camera Replacement: adım 7, 1 resimden 1.
      • Use the small blue plastic opening tool to lift the contact attached to the battery from the motherboard of the phone.
      FixBot'a Sor
      Yorum Ekle
    8. BLU Energy X Plus Camera Replacement: adım 8, 2 resimden 1. BLU Energy X Plus Camera Replacement: adım 8, 2 resimden 2.
      • Use the small blue plastic opening tool to lift the battery from the bottom with little force because the battery will be glued in.
      • Then, use your hand to remove the battery completely.
      FixBot'a Sor
      Yorum Ekle
    1. BLU Energy X Plus Camera Replacement, Camera: adım 9, 2 resimden 1. BLU Energy X Plus Camera Replacement, Camera: adım 9, 2 resimden 2.
      • Disconnect the contact patch using the small blue plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. BLU Energy X Plus Camera Replacement: adım 10, 1 resimden 1.
      • Loosen the camera from the glue using the small blue plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. BLU Energy X Plus Camera Replacement: adım 11, 2 resimden 1. BLU Energy X Plus Camera Replacement: adım 11, 2 resimden 2.
      • After loosening the glue from the bottom of the camera, lift the camera out of the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
woodjake94
638 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-121, Cagle Spring 2016 USF Tampa, Team 2-121, Cagle Spring 2016 üyesi
USFT-CAGLE-S16S2G121
4 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 79
Her zaman: 901
