Ana içeriğe geç
BLU Energy X Plus Speaker Replacement
Neye ihtiyacın var
  1. BLU Energy X Plus Speaker Replacement, Battery: adım 1, 2 resimden 1. BLU Energy X Plus Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Before disassembling your BLU Energy X Plus, make sure it is powered off.
    • Flip your device to the left side facing up and take out the SD card tray using the SIM card eject tool. You will insert the tool in at an angle and lift the tray up.
    FixBot'a Sor
    Yorum Ekle
  2. BLU Energy X Plus Speaker Replacement: adım 2, 2 resimden 1. BLU Energy X Plus Speaker Replacement: adım 2, 2 resimden 2.
    • Flip your device to the right side facing up and use the SIM card eject tool to remove the SIM card by pushing the tool in the hole. You will feel a button click and the tray should slide out 2mm. You will then use your fingers to pull the tray out.
    FixBot'a Sor
    Yorum Ekle
  3. BLU Energy X Plus Speaker Replacement: adım 3, 1 resimden 1.
    • Flip your device over so your back cover is facing up.
    FixBot'a Sor
    Yorum Ekle
  4. BLU Energy X Plus Speaker Replacement: adım 4, 2 resimden 1. BLU Energy X Plus Speaker Replacement: adım 4, 2 resimden 2.
    • Take the blue plastic opening tool and insert it in-between the back of the phone and the chrome trim. Go all the way around the device slowly to take the back cover off.
    FixBot'a Sor
    Yorum Ekle
  5. BLU Energy X Plus Speaker Replacement: adım 5, 2 resimden 1. BLU Energy X Plus Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the six silver screws from the cover plate, and one black screw from the top.
    • Use the screwdriver head J000 to remove all the screws.
    • Six silver screws, all 1.5mm in length.
    • One black screw, 1mm in length.
    FixBot'a Sor
    Yorum Ekle
  6. BLU Energy X Plus Speaker Replacement: adım 6, 1 resimden 1.
    • After all the screws are out, lift the protective metal cover off of the phone. Lift from the bottom of the cover.
    FixBot'a Sor
    Yorum Ekle
  7. BLU Energy X Plus Speaker Replacement: adım 7, 1 resimden 1.
    • Use the small blue plastic opening tool to lift the contact attached to the battery from the motherboard of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. BLU Energy X Plus Speaker Replacement: adım 8, 2 resimden 1. BLU Energy X Plus Speaker Replacement: adım 8, 2 resimden 2.
    • Use the small blue plastic opening tool to lift the battery from the bottom with little force because the battery will be glued in.
    • Then, use your hand to remove the battery completely.
    FixBot'a Sor
    Yorum Ekle
  9. BLU Energy X Plus Speaker Replacement, Speaker: adım 9, 1 resimden 1.
    • Remove the four silver screws using a J000 screwdriver bit .
    • Four silver screws, all 1.5mm in length.
    FixBot'a Sor
    Yorum Ekle
  10. BLU Energy X Plus Speaker Replacement: adım 10, 1 resimden 1.
    • There will be a fifth silver screw that is covered by a white sticker. Remove this screw using the J000 screw driver head.
    • One silver screw, 1.5mm in length.
    FixBot'a Sor
    Yorum Ekle
  11. BLU Energy X Plus Speaker Replacement: adım 11, 2 resimden 1. BLU Energy X Plus Speaker Replacement: adım 11, 2 resimden 2.
    • Lift the module where the speaker is located.
    FixBot'a Sor
    Yorum Ekle
Sonuç
woodjake94
638 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-121, Cagle Spring 2016 USF Tampa, Team 2-121, Cagle Spring 2016 üyesi
USFT-CAGLE-S16S2G121
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 822
