Ana içeriğe geç
BLU Grand M2 Rear Camera Replacement
Neye ihtiyacın var
  1. BLU Grand M2 Rear Camera Replacement, Confirm the Device: adım 1, 2 resimden 1. BLU Grand M2 Rear Camera Replacement, Confirm the Device: adım 1, 2 resimden 2.
    • Check the front panel and confirm you are repairing the BLU Grand M2 (figure 1)
    • Turn the device over and identify the the rear-facing camera (figure 2) This is what you will be replacing
  2. BLU Grand M2 Rear Camera Replacement: adım 2, 1 resimden 1.
    • Locate the two torx screws at the bottom of the phone and remove them using the T2 Torx Screwdriver.
  3. BLU Grand M2 Rear Camera Replacement: adım 3, 1 resimden 1.
    • Use the suction and pry tools to carefully remove the black plate.
    • Be cautious!! Do not damage the phone display or inside components while using pry and suction tools.
  4. BLU Grand M2 Rear Camera Replacement: adım 4, 1 resimden 1.
    • Identify the back-panel camera in the left -hand corner of the open device. (Figure 1)
  5. BLU Grand M2 Rear Camera Replacement: adım 5, 3 resimden 1. BLU Grand M2 Rear Camera Replacement: adım 5, 3 resimden 2. BLU Grand M2 Rear Camera Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the Plastic Pry Tool to carefully to lift the tab on the right-hand side of the connector.
    • Carefully remove camera from housing using a pair of tweezers.
Sonuç
Alan Rodriguez
311 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team S1-G3, Luster Fall 2018 Gateway, Team S1-G3, Luster Fall 2018 üyesi
GCC-LUSTER-F18S1G3
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 430
