Ana içeriğe geç
BLU Life X8 Motherboard Replacement
Neye ihtiyacın var
  1. BLU Life X8 Motherboard Replacement, Battery: adım 1, 2 resimden 1. BLU Life X8 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
    FixBot'a Sor
    Yorum Ekle
  2. BLU Life X8 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use your thumb to pry off the back panel once the gap is large enough.
    FixBot'a Sor
    Yorum Ekle
  3. BLU Life X8 Motherboard Replacement: adım 3, 1 resimden 1.
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
    FixBot'a Sor
    Yorum Ekle
  4. BLU Life X8 Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. BLU Life X8 Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
    FixBot'a Sor
    Yorum Ekle
  5. BLU Life X8 Motherboard Replacement: adım 5, 1 resimden 1.
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
    FixBot'a Sor
    Yorum Ekle
  6. BLU Life X8 Motherboard Replacement: adım 6, 1 resimden 1.
    • Once all the clips have been released, lift the frame and set it aside.
    FixBot'a Sor
    Yorum Ekle
  7. BLU Life X8 Motherboard Replacement: adım 7, 2 resimden 1. BLU Life X8 Motherboard Replacement: adım 7, 2 resimden 2.
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. BLU Life X8 Motherboard Replacement: adım 8, 3 resimden 1. BLU Life X8 Motherboard Replacement: adım 8, 3 resimden 2. BLU Life X8 Motherboard Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
    FixBot'a Sor
    Yorum Ekle
  9. BLU Life X8 Motherboard Replacement: adım 9, 1 resimden 1.
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
    FixBot'a Sor
    Yorum Ekle
  10. BLU Life X8 Motherboard Replacement: adım 10, 1 resimden 1.
    • Slowly lift the vibration motor away from the frame and peel up the tape.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alexander Prasil
555 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Nance Fall 2017 USF Tampa, Team S1-G2, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G2
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
These steps sure was easy then i thought it would be.
Sweetie Tufele - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 40
Her zaman: 784
