Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
The motherboard of the phone is the main circuit board that holds the memory and the CPU. Since replacing it is a difficult and sometimes necessary process, this guide will explain how to access, remove, and replace your BLU Life X8 motherboard.
  1. Flip the phone over so that the screen is facing down. Slide the opening tool between the micro-USB port and the back cover.
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. Use your thumb to pry off the back panel once the gap is large enough.
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. Once the back panel is off, locate the indent at the bottom of the battery.
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
  4. Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device. Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
  5. Wedge the opening tool into the seam of between the screen and the gray frame.
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
  6. Once all the clips have been released, lift the frame and set it aside.
    • Once all the clips have been released, lift the frame and set it aside.
  7. Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard. Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
  8. Use the tweezers to peel away the mesh tape and reveal the ribbon connectors. Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them. Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
  9. The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
  10. Slowly lift the vibration motor away from the frame and peel up the tape.
    • Slowly lift the vibration motor away from the frame and peel up the tape.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexander Prasil
534 İtibar
5 adet Kılavuz yazıldı
Takım
USF Tampa, Team S1-G2, Nance Fall 2017 USF Tampa, Team S1-G2, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 251
