Ana içeriğe geç
BLU Life X8 Screen Replacement
Neye ihtiyacın var
  1. BLU Life X8 Screen Replacement, Battery: adım 1, 2 resimden 1. BLU Life X8 Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. BLU Life X8 Screen Replacement: adım 2, 1 resimden 1.
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. BLU Life X8 Screen Replacement: adım 3, 1 resimden 1.
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
  4. BLU Life X8 Screen Replacement, Motherboard: adım 4, 2 resimden 1. BLU Life X8 Screen Replacement, Motherboard: adım 4, 2 resimden 2.
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
  5. BLU Life X8 Screen Replacement: adım 5, 1 resimden 1.
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
  6. BLU Life X8 Screen Replacement: adım 6, 1 resimden 1.
    • Once all the clips have been released, lift the frame and set it aside.
  7. BLU Life X8 Screen Replacement: adım 7, 2 resimden 1. BLU Life X8 Screen Replacement: adım 7, 2 resimden 2.
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
  8. BLU Life X8 Screen Replacement: adım 8, 3 resimden 1. BLU Life X8 Screen Replacement: adım 8, 3 resimden 2. BLU Life X8 Screen Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
  9. BLU Life X8 Screen Replacement: adım 9, 1 resimden 1.
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
  10. BLU Life X8 Screen Replacement: adım 10, 1 resimden 1.
    • Slowly lift the vibration motor away from the frame and peel up the tape.
  11. BLU Life X8 Screen Replacement, Daughterboard: adım 11, 1 resimden 1.
    • Use the plastic opening tool to pry off the plastic guard covering the daughterboard and USB port.
  12. BLU Life X8 Screen Replacement: adım 12, 1 resimden 1.
    Satın Al
    • Remove the transparent tape covering one of the ribbon connectors using the tweezers.
  13. BLU Life X8 Screen Replacement: adım 13, 3 resimden 1. BLU Life X8 Screen Replacement: adım 13, 3 resimden 2. BLU Life X8 Screen Replacement: adım 13, 3 resimden 3.
    • Use the tweezers to lift the black and beige tabs securing the ribbon cables.
    • Pull back on the ribbon cables to release them from their connectors.
  14. BLU Life X8 Screen Replacement: adım 14, 1 resimden 1.
    • Lift the daughterboard from the frame using the plastic opening tool.
  15. BLU Life X8 Screen Replacement, Screen: adım 15, 1 resimden 1.
    • Take off the sticker and the ribbon cables glued to the back of the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexander Prasil
543 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Nance Fall 2017 USF Tampa, Team S1-G2, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 455
