Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Bring life back to your Blu Life XL with a new battery. This guide instructs you to detach the rear panel assembly and replace the battery.
For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
Remove the rear cover using your hands at the lip on the device back cover. No tools required.
Bir başkası bu kılavuzu tamamladı.
