Ana içeriğe geç
BLU Life XL Charging Port Replacement
Neye ihtiyacın var
  1. BLU Life XL Charging Port Replacement, Battery: adım 1, 3 resimden 1. BLU Life XL Charging Port Replacement, Battery: adım 1, 3 resimden 2. BLU Life XL Charging Port Replacement, Battery: adım 1, 3 resimden 3.
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
  2. BLU Life XL Charging Port Replacement: adım 2, 3 resimden 1. BLU Life XL Charging Port Replacement: adım 2, 3 resimden 2. BLU Life XL Charging Port Replacement: adım 2, 3 resimden 3.
    • Remove the old battery.
    • For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
  3. BLU Life XL Charging Port Replacement, Charging Port: adım 3, 2 resimden 1. BLU Life XL Charging Port Replacement, Charging Port: adım 3, 2 resimden 2.
    • Remove twelve 3mm Phillips #000 screws from the rear plate.
  4. BLU Life XL Charging Port Replacement: adım 4, 2 resimden 1. BLU Life XL Charging Port Replacement: adım 4, 2 resimden 2.
    • Remove the plastic frame on the device using an opening tool.
    • Firmly press the tool into the gap between the front glass and rear plate.
    • The gap is located on all sides of the phone.
    • Run the tool through this gap along the entire edge of the phone to separate the plastic frame from the phone.
  5. BLU Life XL Charging Port Replacement: adım 5, 3 resimden 1. BLU Life XL Charging Port Replacement: adım 5, 3 resimden 2. BLU Life XL Charging Port Replacement: adım 5, 3 resimden 3.
    • Disconnect lower PCB antenna connection.
    • Disconnect lower PCB data cable connection.
    • Remove the single JIS #000 3mm screw from the PCB board.
  6. BLU Life XL Charging Port Replacement: adım 6, 1 resimden 1.
    • Remove the haptic motor at bottom left of the device. This will require a prying tool, as the motor is glued to the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Euan Gordon
164 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Eyestone Spring 2018 USF Tampa, Team S2-G5, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 1,952
