Ana içeriğe geç
BLU Life XL Rear Camera Replacement
Neye ihtiyacın var
  1. BLU Life XL Rear Camera Replacement, Rear Camera: adım 1, 3 resimden 1. BLU Life XL Rear Camera Replacement, Rear Camera: adım 1, 3 resimden 2. BLU Life XL Rear Camera Replacement, Rear Camera: adım 1, 3 resimden 3.
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Rear Camera Replacement: adım 2, 2 resimden 1. BLU Life XL Rear Camera Replacement: adım 2, 2 resimden 2.
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Rear Camera Replacement: adım 3, 2 resimden 1. BLU Life XL Rear Camera Replacement: adım 3, 2 resimden 2.
    • Insert the plastic prying tool in between the plastic frame and the device.
    • Keep the phone on the surface with its screen down.
  4. BLU Life XL Rear Camera Replacement: adım 4, 2 resimden 1. BLU Life XL Rear Camera Replacement: adım 4, 2 resimden 2.
    • Use the plastic prying tool to gently push the rear camera out from its socket.
    • Take the camera out and set it aside.
  5. BLU Life XL Rear Camera Replacement: adım 5, 2 resimden 1. BLU Life XL Rear Camera Replacement: adım 5, 2 resimden 2.
    • Carefully place the new camera in the camera socket.
    • Apply a little force on the top of the camera to slide it in the socket.
    • Pop the camera in the socket and make sure its stable.
Sonuç
Shantanu Malhotra
178 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Eyestone Spring 2018 USF Tampa, Team S2-G5, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 246
