Ana içeriğe geç
BLU Life XL Volume Control Buttons Replacement
Neye ihtiyacın var
  1. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: adım 1, 3 resimden 1. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: adım 1, 3 resimden 2. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: adım 1, 3 resimden 3.
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Volume Control Buttons Replacement: adım 2, 2 resimden 1. BLU Life XL Volume Control Buttons Replacement: adım 2, 2 resimden 2.
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Volume Control Buttons Replacement: adım 3, 2 resimden 1. BLU Life XL Volume Control Buttons Replacement: adım 3, 2 resimden 2.
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Volume Control Buttons Replacement: adım 4, 3 resimden 1. BLU Life XL Volume Control Buttons Replacement: adım 4, 3 resimden 2. BLU Life XL Volume Control Buttons Replacement: adım 4, 3 resimden 3.
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
Sonuç
James Whitlow
342 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Eyestone Spring 2018 USF Tampa, Team S2-G5, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 287
