Ana içeriğe geç
BLU Studio 5.0 II Motherboard Replacement
Neye ihtiyacın var
  1. BLU Studio 5.0 II Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. BLU Studio 5.0 II Motherboard Replacement: adım 2, 2 resimden 1. BLU Studio 5.0 II Motherboard Replacement: adım 2, 2 resimden 2.
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. BLU Studio 5.0 II Motherboard Replacement: adım 3, 3 resimden 1. BLU Studio 5.0 II Motherboard Replacement: adım 3, 3 resimden 2. BLU Studio 5.0 II Motherboard Replacement: adım 3, 3 resimden 3.
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  4. BLU Studio 5.0 II Motherboard Replacement, Back Case: adım 4, 1 resimden 1.
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  5. BLU Studio 5.0 II Motherboard Replacement: adım 5, 3 resimden 1. BLU Studio 5.0 II Motherboard Replacement: adım 5, 3 resimden 2. BLU Studio 5.0 II Motherboard Replacement: adım 5, 3 resimden 3.
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
  6. BLU Studio 5.0 II Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. BLU Studio 5.0 II Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. BLU Studio 5.0 II Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Locate the following adhesive buttons on the right and left side of the motherboard. These are the volume and power buttons.
    • Use a spudger to carefully separate them from the circuit board.
  7. BLU Studio 5.0 II Motherboard Replacement: adım 7, 3 resimden 1. BLU Studio 5.0 II Motherboard Replacement: adım 7, 3 resimden 2. BLU Studio 5.0 II Motherboard Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Locate these two ZIF connectors on the top and left side of the motherboard.
    • Use a spudger to flip up and unlock the black tab on the connector.
    • Use tweezers to pull the ribbon cables out of their connectors.
  8. BLU Studio 5.0 II Motherboard Replacement: adım 8, 3 resimden 1. BLU Studio 5.0 II Motherboard Replacement: adım 8, 3 resimden 2. BLU Studio 5.0 II Motherboard Replacement: adım 8, 3 resimden 3.
    • Locate the indicated connector on the top side of the motherboard.
    • Use a pair of tweezers to gently lift the connector from the circuit board.
  9. BLU Studio 5.0 II Motherboard Replacement: adım 9, 3 resimden 1. BLU Studio 5.0 II Motherboard Replacement: adım 9, 3 resimden 2. BLU Studio 5.0 II Motherboard Replacement: adım 9, 3 resimden 3.
    • Remove the three 3mm screws on the motherboard using a Phillips #00 screwdriver.
    • Use a spudger or tweezers to carefully lift and remove the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ricardo Sarabia
1.069 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-5, Cheng Spring 2016 USF Tampa, Team 7-5, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G5
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
that left the speaker disconnected?
Rodolfo Leal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,946
