Ana içeriğe geç
BLU Tank II Front Panel Replacement
Neye ihtiyacın var
  1. BLU Tank II Front Panel Replacement, Back Panel: adım 1, 2 resimden 1. BLU Tank II Front Panel Replacement, Back Panel: adım 1, 2 resimden 2.
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Front Panel Replacement, Battery: adım 2, 1 resimden 1.
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Front Panel Replacement, Front Panel: adım 3, 2 resimden 1. BLU Tank II Front Panel Replacement, Front Panel: adım 3, 2 resimden 2.
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Front Panel Replacement: adım 4, 1 resimden 1.
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
Sonuç
David Kelchner
632 İtibar
6 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 217
