Ana içeriğe geç
BLU Tank II Outer Lens Replacement
Neye ihtiyacın var
  1. BLU Tank II Outer Lens Replacement, Back Panel: adım 1, 2 resimden 1. BLU Tank II Outer Lens Replacement, Back Panel: adım 1, 2 resimden 2.
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Outer Lens Replacement, Battery: adım 2, 1 resimden 1.
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Outer Lens Replacement, Front Panel: adım 3, 2 resimden 1. BLU Tank II Outer Lens Replacement, Front Panel: adım 3, 2 resimden 2.
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Outer Lens Replacement: adım 4, 1 resimden 1.
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
  5. BLU Tank II Outer Lens Replacement, Motherboard: adım 5, 2 resimden 1. BLU Tank II Outer Lens Replacement, Motherboard: adım 5, 2 resimden 2.
    • Locate the two 2.5mm screws (red circles in image) and remove them with the Philips 00 screwdriver used previously.
  6. BLU Tank II Outer Lens Replacement: adım 6, 3 resimden 1. BLU Tank II Outer Lens Replacement: adım 6, 3 resimden 2. BLU Tank II Outer Lens Replacement: adım 6, 3 resimden 3.
    • Once screws are removed, separate the motherboard and outer lens by carefully pushing the motherboard out with your hand as displayed in the image.
  7. BLU Tank II Outer Lens Replacement, Outer Lens: adım 7, 2 resimden 1. BLU Tank II Outer Lens Replacement, Outer Lens: adım 7, 2 resimden 2.
    • Once separated from the motherboard, the outer lens can now be replaced.
Sonuç
David Kelchner
632 İtibar
6 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 140
