Giriş
Neye ihtiyacın var
Remove the P2 screws.
Remove the SIM and SD cards, as well as the adapter.
Pull off the protective cover from the camera.
Remove the screws with a #00 Phillips screwdriver.
Use a spudger to carefully apply pressure to the indicated areas to remove the cover.
Remove the microphone/speaker board assembly by pulling downward.
The battery has a small notch to facilitate removal, but the battery has been glued in place.
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
2 Yorum
Umm not sure what BLU Vivo 5 your giving these instructions for, my BLU Vivo 5 has no screws. Looks the same except for bottom speaker area, mine has type c and other wither side 2 slots one for mic one for speaker, no screws.
This guide is NOT for BLU Vivo 5. It's probably for the mini version. The BLU vivo 5 doesn't have screws at bottom...
