Ana içeriğe geç
BLU WIN HD LTE Battery Replacement
Neye ihtiyacın var
  1. BLU WIN HD LTE Battery Replacement, Back Case: adım 1, 1 resimden 1.
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Battery Replacement: adım 2, 1 resimden 1.
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Battery Replacement, Frame Cover: adım 3, 1 resimden 1.
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Battery Replacement: adım 4, 1 resimden 1.
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Battery Replacement, Battery: adım 5, 2 resimden 1. BLU WIN HD LTE Battery Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the battery out using the black nylon spudger.
    • Battery is secured by glue so use more force to take it out.
Sonuç
2 Yorum
I replaced the battery but now there is a symbol on the screen, box with a question mark, what does that mean?
raybrooks - Yanıt
I hope someone else has had this issue an has a solution. Thank you in advance for any and all help.
raybrooks - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 663
