Ana içeriğe geç
BLV MGN Cube Klipper Neopixels Replacement
  1. BLV MGN Cube Klipper Neopixels Replacement, Wiring: adım 1, 1 resimden 1.
    • Wiring schematic
  2. BLV MGN Cube Klipper Neopixels Replacement, NeoPixel Setup Step 1: adım 2, 2 resimden 1. BLV MGN Cube Klipper Neopixels Replacement, NeoPixel Setup Step 1: adım 2, 2 resimden 2.
    • Thanks to Pawel Drylenko we now have a working solution to incorporate the Arduino Neopixels with Klipper. We're created shell scripts to make installation easier. SSH into the RPI. Run the following commands:
    • git clone https://github.com/armysolo/neopixels_in...
    • cd into the newly created "neopixels_install" directory
    • cd neopixels_install/
    • Run the script for step 1
    • sh neopixel_step_1.sh
    • When prompted reboot the pi
    • SSH back into the RPI. Run the following commands
    • cd into the "neopixels_install" directory
    • Run the script for step 2
    • sh neopixel_step_2.sh
    • when prompted enter password for sudo
  3. BLV MGN Cube Klipper Neopixels Replacement, NeoPixel Setup Step 3: adım 4, 1 resimden 1.
    • Run the script for step 3
    • sh neopixel_step_3.sh
    • You'll need to enter your sudo password twice
    • If you have your NeoPixels already wired you should see them light up
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
David Husolo
9.162 İtibar
33 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 2,020
