Giriş
Follow this guide to replace the BMS in Zerotow 3024wH battery.
Only to be performed by competent people with battery experience.
Start with a clean work bench
Remove all conductive a tools from your work bench
Wear safety glasses
Use a stanley knife to cut though the sealant of the battery case
Use caution when doing this
Slowly lever the case apart.
Start at the bottom and work your way around to the handle
Fully open the case
The glue is quite strong, use you hand inside to seperate the case from the heat shrink
Be careful to not damage the delicate switch wires
Cut off the thick black shrink wrap
The main power cables and switch remain connected to the top cover.
Gently release and remove the switch cables from any adhesive so that they are not under stain when opening the case.
Rest the top cover on a box or similar to prevent staining the cables
Remove the heat shrink from the battery pack.
go slowly at the cable end as to not break or stain any thinn switch cables
Remove the negative terminal
Cover the negative terminal with tape
Unplug the 4 connectors from the BMS. these will all be reused. do not cut.
Cut the large main negative cables from the BMS. There are 3-4 at each end of the BMS.
Cut the black switch light wire as close to the BMS as possible.
A connector is soldered to this in step 14
Fully remove old BMS
Desolder short wires from the main negative
Ensure all old solder locations are smooth
Remove fibreglass from old BMS and install on New BMS
Locate new BMS as shown
Solder main Negatives as shown
The new BMS has all of the connections from one end only.
Solder or crimp the eye terminal to the switch light wire that was cut in step 10
The New BMS has different cable routing than the old one
Cut a slot in the fibreglass for the for the new BMS cables
Wrap the fiberglass sheets back around the BMS
Use duct of fiberglass tape close and seal the fiberglass sheets around the battery pack
Turn the switch on and off to check that the red light turns on and off.
Check the BMS app to ensure the all cells and connected to the ballance leads
Use ant BMS V2 app from the app store
