Ana içeriğe geç
BMW M-Colored LED Front Kidney Grille Installation
Neye ihtiyacın var
  1. BMW M-Colored LED Front Kidney Grille Installation, Prep Work: adım 1, 1 resimden 1.
    • You will need to remove a couple of bolts on the front bumper before you can start removing the BMW factory kidney grille.
  2. BMW M-Colored LED Front Kidney Grille Installation, Taking out the factory kidney grille: adım 2, 3 resimden 1. BMW M-Colored LED Front Kidney Grille Installation, Taking out the factory kidney grille: adım 2, 3 resimden 2. BMW M-Colored LED Front Kidney Grille Installation, Taking out the factory kidney grille: adım 2, 3 resimden 3.
    • When you have enough clearance space, you can wedge your hand in between the gap to pop out the stock kidney grille.
    • Keep maneuvering your hand in the space to ease the stock grille out.
  3. BMW M-Colored LED Front Kidney Grille Installation, Watch out for the clips: adım 3, 1 resimden 1.
    • Detach the stock kidney grille from the clips holding it onto the BMW front bumper.
  4. BMW M-Colored LED Front Kidney Grille Installation, Starting the swap: adım 4, 2 resimden 1. BMW M-Colored LED Front Kidney Grille Installation, Starting the swap: adım 4, 2 resimden 2.
    • Pull out the factory kidney grille.
  5. BMW M-Colored LED Front Kidney Grille Installation, Putting in the new LED kidney grille: adım 5, 2 resimden 1. BMW M-Colored LED Front Kidney Grille Installation, Putting in the new LED kidney grille: adım 5, 2 resimden 2.
    • Use your hand to apply a bit of pressure to pop the new LED M-stripe kidney grille in place
    • Secure the new LED grille onto the clips.
    • Note: the M-Colored LED stripe is only on the right grille assembly.
    • Tap the wire to the ACC or other 12V power source.
    • Repeat on the other side.
  6. BMW M-Colored LED Front Kidney Grille Installation, Put everything back: adım 6, 1 resimden 1.
    • Put the bolts back into the BMW front bumper.
    • Enjoy your new M-Colored BMW LED Illuminated kidney grille.
Sonuç
You can see that you didn't need to be an advanced car installer to attempt this. This makes the installation great for beginners as well as seasoned car fans alike.
2 farklı kişi bu kılavuzu tamamladı.
Eric Wu
3.357 İtibar
23 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 61
Her zaman: 9,885
