Ana içeriğe geç
BMX Handlebars Replacement
Neye ihtiyacın var
  1. BMX Handlebars Replacement, BMX Handlebars: adım 1, 1 resimden 1.
    • Locate the stem of the bike connecting the handlebars to the steerer tube of the fork.
  2. BMX Handlebars Replacement: adım 2, 2 resimden 1. BMX Handlebars Replacement: adım 2, 2 resimden 2.
    • Remove the four bolts from the face of stem with a 6mm Allen key.
    • BMX bolts typically use a 6mm standard, but some equipment may differ.
  3. BMX Handlebars Replacement: adım 3, 1 resimden 1.
    • Remove the faceplate of the stem.
  4. BMX Handlebars Replacement: adım 4, 1 resimden 1.
    • Remove the old handlebars.
    • Place the new bars in the curved area of the stem where the old bars were located.
  5. BMX Handlebars Replacement: adım 5, 1 resimden 1.
    • Place the faceplate of the stem back on and align the screw holes.
  6. BMX Handlebars Replacement: adım 6, 1 resimden 1.
    • Insert the four screws back into the stem and tighten them half way with the 6mm Allen wrench.
  7. BMX Handlebars Replacement: adım 7, 2 resimden 1. BMX Handlebars Replacement: adım 7, 2 resimden 2.
    • Align your handlebars so they are straight, balanced, and to your liking.
    • Tighten the bolts in an "X" pattern a half turn at a time.
  8. BMX Handlebars Replacement: adım 8, 1 resimden 1.
    • Pull up on your handlebars and make sure they are tight enough that they do not move.
Sonuç
To reassemble your device, follow these instructions in order.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 651
