Ana içeriğe geç
BOSE SoundTouch 30 Display Assembly Replacement
Neye ihtiyacın var
  1. BOSE SoundTouch 30 Display Assembly Replacement, Base Plate: adım 1, 2 resimden 1. BOSE SoundTouch 30 Display Assembly Replacement, Base Plate: adım 1, 2 resimden 2.
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
    FixBot'a Sor
    Yorum Ekle
  2. BOSE SoundTouch 30 Display Assembly Replacement, Display Assembly: adım 2, 1 resimden 1.
    • Remove the three 15.5mm PH2 screws holding the front-mesh grille in place.
    FixBot'a Sor
    Yorum Ekle
  3. BOSE SoundTouch 30 Display Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the grille by gripping the edges and pulling upwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
    FixBot'a Sor
    Yorum Ekle
  4. BOSE SoundTouch 30 Display Assembly Replacement: adım 4, 2 resimden 1. BOSE SoundTouch 30 Display Assembly Replacement: adım 4, 2 resimden 2.
    • Remove the six 8.9mm T9 torx screws holding the display assembly down.
    • The display assembly can now be lifted out of the grille so that a new one can be put in.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Brennen Irey
1.269 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S16-G2, Livingston Spring 2018 Cal Poly, Team S16-G2, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S16G2
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Display assembly price
imrankhannnnn786 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 69
Her zaman: 5,369
