Giriş
This guide goes over the steps needed to remove the subwoofer from the device.
Neye ihtiyacın var
Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
Remove the five 15.5 mm PH2 screws holding the motherboard down.
Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
Remove the motherboard.
Remove the eight 15.5 mm PH2 screws holding the plastic insert down.
Remove the plastic insert.
2 farklı kişi bu kılavuzu tamamladı.
