Ana içeriğe geç
BRCK v1 Battery Replacement
Neye ihtiyacın var
  1. BRCK v1 Battery Replacement, Antenna: adım 1, 1 resimden 1.
    • Stand the device on its side so the antenna is sitting on the top.
  2. BRCK v1 Battery Replacement: adım 2, 2 resimden 1. BRCK v1 Battery Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the tweezers to grip the neck of the antenna(the part closest to the device).
    • Use opposite hand to twist off the body of the antenna.
  3. BRCK v1 Battery Replacement, Top Cover: adım 3, 1 resimden 1.
    • Place the face of the device showing BRCK face up.
  4. BRCK v1 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  5. BRCK v1 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the top cover.
  6. BRCK v1 Battery Replacement, Motherboard: adım 6, 2 resimden 1. BRCK v1 Battery Replacement, Motherboard: adım 6, 2 resimden 2.
    • Remove the nut and washer from the RF connector, located where the antenna was connected.
  7. BRCK v1 Battery Replacement: adım 7, 2 resimden 1. BRCK v1 Battery Replacement: adım 7, 2 resimden 2.
    • Unplug the red, black, and yellow wire connection by lifting up.
  8. BRCK v1 Battery Replacement: adım 8, 3 resimden 1. BRCK v1 Battery Replacement: adım 8, 3 resimden 2. BRCK v1 Battery Replacement: adım 8, 3 resimden 3.
    • Carefully insert tweezers under the black tab, and lift to release the clip.
    • Slide the ribbon out from under the clip to free the motherboard.
  9. BRCK v1 Battery Replacement: adım 9, 1 resimden 1.
    • Remove outside rubber covers by lifting them out of place.
  10. BRCK v1 Battery Replacement: adım 10, 3 resimden 1. BRCK v1 Battery Replacement: adım 10, 3 resimden 2. BRCK v1 Battery Replacement: adım 10, 3 resimden 3.
    • Slowly lift the motherboard out from the device by lifting it from the end next to the ribbon connection.
    • Lift and pull out of place.
  11. BRCK v1 Battery Replacement, Battery: adım 11, 3 resimden 1. BRCK v1 Battery Replacement, Battery: adım 11, 3 resimden 2. BRCK v1 Battery Replacement, Battery: adım 11, 3 resimden 3.
    • Flip device upside down. Hold the device and tap into your other hand with varying force to remove battery.
    • This may take a few tries to remove the battery.
Sonuç
Jeret Buerger
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-3, Lancaster Spring 2015 Cal Poly, Team 12-3, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G3
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 250
